POINTCLOUDFITCYLINDER command
Creates cylinders in Point Clouds.
                Icon:
This command can only operate in Bubble Viewer.
Method
Open Bubble Viewer and choose two points along the axis to create a cylinder.
After selecting the second point, the cylinder is inserted in model space. Press Ctrl+A keys to sync the drawing view to match the Bubble Viewer and see the new inserted cylinder.
Options within the command
- Accept
 - Accepts the new inserted cylinder.
- Decline
 - Does not accept the new inserted cylinder.
