POINTCLOUDDETECTFLOORS command
Generates volume type sections.
Icon:
Generates volume type sections for each floor and ceiling found in a point cloud representing a building.
Note: The POINTCLOUDDETECTFLOORS command is used as a step in the point cloud Scan to BIM workflow. See the article Point cloud Scan to BIM workflow.
Options within the command
- Full
- Automatically detects floors for the entire point cloud.
- Selection
- Specify the point cloud area where to detect floors.
Note: Adjust the position and/or size of a detected volume type section by selecting it (click the section line) and using the green grips.
- Create spatial elements
- Choose Yes to let the command create spatial elements based on the detected floors height.
