PSETUPIN command
Imports user defined page setups.
Opens the Select Page Setup From File dialog box to select a DWG, DWT, or DXF file from which to import user defined page setups. After selecting the file and choosing Open, the Import Page Setups dialog box displays. It enables you to choose which page setups from the selected file you wish to import into the current drawing.
Note: Only user defined page setups can be imported. Default page setups such as the Model tab or Layout tabs, cannot be renamed or imported.
Source Drawing
Displays the source of the drawing used to import the page setup(s).
Page setups
Specifies the name and the location of each page setup from the list:
  • Name: specifies the names of page setups in the drawing. When the drawing does not contain page setup, the dialog box is empty.
  • Location: specifies the layout and model locations of page setups.
Details
Includes information about the device name, plotter, plot size, location and a description field.
