RECTANG command
Creates a polyline in the shape of a rectangle.
                Icon:
Alias: REC, RECT, RECTANGLE
Creates a closed, four-sided rectangular polyline in the shape of a rectangle, square, and variants with chamfers or fillets.
- First corner
 - Second corner
 - Length
 - Width
Method
This command has 5 methods to begin creating a rectangle:
- Select first corner of rectangle
 - Rotated
 - Square
 - Area
 - Dimensions
Options within the command
 - Allows you to begin creating a rectangle by specifying the first corner of a rectangle.
- Other corner of rectangle
 - Specifies the opposite corner of the rectangle. The rectangle is drawn parallel to the X and Y axes.
- Chamfer
 - Specifies the first and second chamfer distance to use for all rectangles.
- First chamfer distance
 - Second chamfer distance
- turn chamfer Off
 - Turns Off the Chamfer option.
- use Default setting
 - Uses the default settings for chamfer, specified by the CHAMFERA, CHAMFERB, CHAMFERC, CHAMFERD, CHAMMODE system variables.
- Fillet
 - Specifies the fillet distance to use for all rectangles.
- Fillet radius
- turn fillet Off
 - Turns Off the Fillet option.
 - Uses the default setting for fillet, specified by the FILLETRAD system variable.
- Rotated
 - Creates a rectangle by specifying two corners and the rotation angle.
- Rotation angle
- Square
 - Begins creating a rectangle by specifying a corner of a square.
- Second corner of square
 - Specifies a corner along the same side of the square to define its length and angle.
- Elevation
 - Specifies the height above the XY-plane to use for all rectangles.
- use Default
 - Uses the default setting for elevation, specified by the ELEVATION system variable.
- Thickness
 - Specifies the thickness of the rectangle line segments. All segments have the same thickness.
- Width of line
 - Specifies the width of the rectangle line segments. All segments have the same width.
- Area
 - Creates a rectangle by specifying its area.
- Length
 - Calculates the rectangle dimension based on length.
- Width
 - Calculates the rectangle dimension based on width.
- Dimensions
 - Creates a rectangle by specifying its length and width.
