SECTIONVIEWS command
Creates section views for civil entities.
Icon:
Method
Select a section line in the drawing, or press Enter to open the Select Section Line Group dialog box for selecting one available section line group.
  1. Name
  2. Parent alignment or string
  3. Number of section lines
Name
Displays the name of a section line group.
Displays the parent alignment or string.
Displays the number of section lines.
After choosing a section line group, the Create Section View dialog box opens.
When selecting a single section line and the Single section view option in the Command line, the Create Section View dialog box contains the Section line name.
Options within the command line
Multiple section views
The Create Section View dialog box opens.
Single section view
The Create Section View dialog box for only one section line opens.
