SKETCH command
Creates lines or polylines from a freehand sketch.
                Icon:
Alias: FREEHAND
Creates a series of individual lines or a polyline by sketching freehand.
Options within the command
- Length of sketch line segments
- Specifies the length of the sketch line segments. A small segment length creates a smoother sketch but increases the size of the drawing. The length is saved in the SKETCHINC variable.
- Press ENTER or click to toggle
- Lowers or raises the pen.- If the pen is lowered, it automatically sketches as you move it.
- If the pen is raised, you can move the cursor without drawing.
   - Pen up
- Pen down
 Note: You can continue raising and lowering the pen to create unlimited sketches until you press X or Q to end the command.
- Erase
- Erases sketch lines sequentially by dragging the cursor along the sketch from either endpoint. Click the left mouse button to stop erasing and start sketching.
- Connect
- Continues to the last sketch point, after raising the pen, by passing the cursor over the end of the previous segment.
- Save and exit
- Saves the sketch and ends the command. Each continuous sketch is saved as a series of individual lines or a polyline based on the SKPOLY variable.
- Quit no save
- Exits the command without saving the sketch.
- Record (save)
- Saves the current sketch without ending the command, allowing you to continue sketching.
