STLOUT command
Export 3D solids and watertight meshes.
                Icon:
Exports 3D solids and watertight meshes in a format that can be used for stereolithography (3D printing).
Method
There are two methods to use STLOUT command:
- Export 3D solids.
 - Export meshes.
Options within the command
- Create binary STL file
 - Determines whether the output file is in binary or ASCII format.
- Select smoothness of objects exported to STL file
 - Adjusts the quality of the exported entities.
- Low
 - Exports with FACETRES = 0.5.
- Medium
 - Exports with FACETRES = 2.0.
- High
 - Exports with FACETRES = 10.
- Default
 - The modeler properties from Settings are used.
