STRINGADDCURVE command
Adds curves to a Civil String.
Icon:
Adds a curve in a PI point of a Civil String entity with the specified radius value.
Note: The default radius value is 10.
Method
Select the Civil String entity and specify each PI point to add a curve.
Options within the command
- Radius
- Allows you to set the radius value.
