STRINGADDPI command
Adds PI (Points of intersections) to a Civil String entity.
Icon:
Adds PI points to a Civil String entity.
Method
Select the Civil String entity, specify each PI point and its elevation.
Options within the command
Surface
Allows you to select a TIN surface from which to extract the elevation.
