account
translation
Bricsys Help Center
STRINGDELETEELEVATIONPOINT command
Deletes elevation points from a Civil String entity.
Icon:
Method
Select the Civil String entity and click to select the elevation point to delete.
Related commands
  • STRING command
  • STRINGADDCURVE command
  • STRINGADDPI command
  • STRINGADDELEVATIONPOINT command
  • STRINGDELETEPI command
  • STRINGELEVATIONFROMSURFACE command
  • STRINGFROMOBJECT command
  • TIN command
Related information
  • Civil Explorer panel
  • Create a TIN Surface
© 2025 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
