STRINGEDITOR command
Edits Civil String entities.
Icon:
Method
Select Civil String entities to open the String Editor dialog box.
- Select String
- Elevations tab
- Horizontal geometry tab
- Statistics tab
Select String
Displays the Civil String for editing. You can select another Civil String from the drop-down list or click
to pick it from the drawing area.
Elevations tab
Lists all points properties of the Civil String for editing.
- Zoom
- Raise/Lower
- Add elevation point
- Get elevation from surface
- Reverse string
- Relative to surface
- String points properties list
- Zoom
- Zooms in the drawing to the selected Civil String.
- Raise / Lower
- Opens the Raise/Lower dialog to set the elevation difference value. This value will be added to the elevations. Negative values decrease the elevation.
- Launches the STRINGADDELEVATIONPOINT command. Adds an elevation point to a Civil String entity.
- Opens the Elevations From Surface dialog box.
- Reverse string
- Changes the direction of the Civil String.
- Displays the selected TIN surface to which a Civil String elevations will be relative. You can select another TIN surface from the drop-down list or click
- Lists all String points properties.Note: Right-click a string point properties line to open a context menu with Zoom to, Pan to, Copy to clipboard, and, depending on the point type, the Delete PI (
) or Delete elevation point (
) options.
Lists all segments properties of the Civil String for editing.
- Add PI
- Add curve
- Delete PI
- Reverse string
- String segments properties
- Add PI
- Launches the STRINGADDPI command.
- Add curve
- Launches the STRINGADDCURVE command.
- Delete PI
- Launches the STRINGDELETEPI command.
- Reverse string
- Lists all String segments properties.
Statistics tab
Lists the general properties of the Civil String.
Points intersection (PI)
Point intersection (PI) read only
Point intersection (PI) shared
Elevation Point
