-TINEXTRACT command
Extracts meshes, solids, points, faces, contours, borders or intersection lines from a TIN surface, Grading, or TIN Volume Surface, via Command line.
Creates a mesh or 3D solid between two TIN Surfaces / Gradings / TIN Volume Surfaces or between a TIN Surface / Grading / TIN Volume Surface and elevation or vertical offset.
Method
Select a surface (TIN Surface / Grading / TIN Volume Surface) and choose which entity want to extract or create.
Options within the command
- Mesh
- Creates a mesh as an offset, between surfaces or as an elevation.
- Solid
- Creates a solid as an offset between surfaces or as an elevation.
- Points
- Extracts all points on the surface.
- Faces
- Extracts all triangular faces of the surface.
- Contours
- Extracts the contours of the surfaces for an elevation.
- Border
- Extracts the outer boundary of the surface.
- Intersection lines
- Extracts 3D Polylines at the intersection between two surfaces (TIN Surfaces, Gradings, or TIN Volume Surfaces).
- TIN Surface
- Extracts a TIN Surface from a Grading or a TIN Volume Surface.
