TYPEDPLANS command
Opens the BIM Typed Plans dialog box.
Icon:
Opens the BIM Typed Plans dialog box, listing all Typed Plans in the Support folder and allowing you to edit them.
- Search
- Context menu
- Edit typed plan
- Add typed plan
Search
Searches all the Typed Plans that matches the words you enter in the search box.
Context menu
- Clone
- Creates a copy of the selected Typed Plan.
- Remove
- Removes the selected Typed Plan.
- Rename
- Edits the name of the selected typed plan. Press Enter to save and apply the changes.
Edit typed plan
Opens the BIM Typed Plan Editor dialog box which allows you to edit the selected Typed Plan.
Note: You can also open the BIM Typed Plan Editor for any Typed Plan by clicking on it's name in the list.
Add typed plan
Creates a new Typed Plan.
You can create a template by clicking on the
button. By default, the Typed Plan is named New Typed Plan with the text highlighted. After you have added a relevant name for the Typed Plan, press Enter to save and apply the changes. The inserted Typed Plans will be sorted alphabetically. Use the scroll bar to navigate through the list.
