UCSICON command
Controls the display of the UCS icon.
The UCS icon is displayed differently, depending on the visual style and workspace.
The colors denote the directions of the axes. It can be controlled by the COLORX, COLORY, COLORZ system variables.
Options within the command
- ucs icon ON
- Displays the UCS icon.
- ucs icon OFf
- Disables the UCS icon.
- display in All views
- Applies the changes to all viewports.
- display at ORigin
- When the origin is outside of the viewport, the UCS icon is displayed at the corner defined by the UCSICONPOS system variable.
- display in Corner
- Displays the UCS icon in the viewport corner defined by the UCSICONPOS system variable.
