-VBALOAD command Loads VBA projects. Description Loads a VBA project; works in the Command line (short for “Visual Basic for Applications”). Parent topic: Command referenceRelated commandsADDINMAN commandAPPLOAD commandVBAIDE commandVBAMAN commandVBARUN command-VBARUN commandVBASECURITY commandVBAUNLOAD commandRelated variablesLICFLAGS system variableVBAMACROS system variable
