BricsCAD Communicator - Getting started
BricsCAD Communicator is an optional plug-in for Pro and higher license levels of BricsCAD that imports and exports 3D data between major CAD formats. Its high-quality conversions facilitate the re-use of 3D CAD data to improve productivity and reduce project costs.
Activating BricsCAD Communicator
After you have installed BricsCAD Communicator on your computer, you need to activate the software.
- Launch the LICENSEMANAGER command.The Bricsys License Manager dialog box displays.
- Under Communicator for BricsCAD, click Manage License.
- The Activate BricsCAD Communicator dialog box displays.
- Click Activate Trial to activate BricsCAD Communicator trial license online.
- Click Activate Now…. You can:
- Type a valid BricsCAD Communicator license key into the License Key field if you are using a Single User or Volume license.
- Type the Server name or local IP address of the license server if you are using a Network license.
- Click the OK button.
The license is registered, and a confirmation dialog box displays.
- Read the text on the dialog box and click the I understand button.
Note:
- To activate BricsCAD Communicator license offline see: Trial: offline (manual) activation or Single or volume license: offline (manual) activation.
- To activate BricsCAD Comunicator Network license on the license server see: Network license: online activation or Network license: offline (manual) activation.
