Choose Window Style dialog box
The Choose Window Style dialog box allows you to specify the style of a window.
A series of parameters is created, which can be edited in the Parameters section of the Properties panel. Rectangular windows and openings have a W (Width) and H (Height) parameter.
Parent topic: Dialog boxes
Related commands
  • BIMWINDOWCREATE command
  • BIMINSERT command
  • BIMCURTAINWALL command
  • BIMGRID command
  • BIMWINDOWUPDATE command
  • PANELIZE command
Related information
  • Properties panel
