Configure Settings dialog box
The Configure Settings dialog box allows you to control how BricsCAD searches for variables and how the differences are handled.
- Find what
- Find
- Find where
- Match case
- Display modified settings in a different color
- Select color
- During drawing comparison, display only settings stored in the drawing
Find what
Type the name of the setting you are looking for.
Find
Searches in the Settings dialog box for the word you have typed.
Find where
Determines which part of the Settings dialog box should be searched.
- In variable names
- Thick this checkbox to search in variable names.
- In variable titles
- Thick this checkbox to search in variable titles.
- In variable values
- Thick this checkbox to search in variable values.
- In variable help
- Thick this checkbox to search in variable help.
- In categories
- Thick this checkbox to search in categories.
Match case
Thick this checkbox to specify that the capitalization of the searched phrase must match that of the words in the Settings dialog box.
Thick this checkbox to see the modified settings in a different color.
Select color
Click this button to select another color.
Thick this checkbox to see the differences for settings stored in the current drawing and another drawing that you open by running the DWGCOMPARE command.
