Customization Groups dialog box
The Customizations Groups dialog box allows you to load or to unload a partial CUI file.
When you install BricsCAD, the default CUI files are copied to the Support folder of your Roamable root folder. (e.g. C:\Users\%username%\AppData\Roaming\Bricsys\BricsCAD\V24x64\en_US\Support).
When you launch BricsCAD the first time, the classic-ribbon.cui file is loaded automatically.
- Loaded Customization Groups
- Load Customization Group from File
A list with the names of the customization files already loaded displays.
To unload a CUI file, select it from the list and click Unload.
Click the browse button to select a partial CUI file and click Load to load it.
Note: There are three standard CUI files available by default:
- Modern
- Classic-ribbon
- Classic-toolbars
