Select Alignment dialog box
Opens via:
  • ALIGNMENTVERTICALMANAGE command
  • ALIGNMENTVIEW command
The Select Alignment dialog box allows you to select a horizontal alignment.
Select in drawing
Allows you to select a horizontal alignment in the drawing.
List of alignments
Allows you to select an available horizontal alignment from the list.
