Select Alignment or String dialog box
Opens via: SECTIONLINES command > press enter key to select from list option
The Select Alignment or String dialog box allows you to select an alignment or a string for creating section lines.
- Select in drawing
- List of alignments and strings
- Select in drawing
- Allows you to select an alignment or a string, or by picking points on a TIN surface in the drawing.
- Allows you to select one available alignment or string from the list.
