Select Custom Arrow Block dialog box
The Select Custom Arrow Block dialog box allows you to choose a block to define the shape of the arrowhead. Opens via the Select arrow option in the Qleader Settings dialog box.
- Select from Drawing Blocks
Specifies one of the blocks in the drawing to use as arrowhead.
