Select Style dialog box
Opens via:
- CIVILPOINT command > Create Civil Points dialog box > Symbol Style option > press the right-side three dots
- CIVILPOINT command > Create Civil Points dialog box > Label Style option > press the right-side three dots
- SECTIONLINES command > Create Section Lines dialog box > Labels Style option > press the right-side three dots
- SECTIONVIEWS command > Create Section View dialog box > Style option > press the right-side three dots
- Style list
- Edit style...
- Copy style...
Style list
Displays the available styles.
Edit style...
Opens the Symbol Style, Label Style Editor , or Section View Style dialog box to edit selected symbol, label, or section view style.
Copy style...
Opens the Symbol Style, Label Style Editor , or Section View Style dialog box to create a copy of the selected symbol, label, or section view style.
Note: The symbol and label styles are defined in the Settings tab of the Civil Explorer panel.
