Shape Style dialog box
Opens via:
  • Civil Explorer panel > Settings tab > context menu of a Shape Style > Create option
  • Calculate Section Volumes dialog box > Material style option > Browse button ()
The Shape Style dialog box allows you to define how the earthwork and structural materials are displayed in a drawing.
Info tab
Displays information about the shape style.
Name
Sets and displays the material style name.
Sets and displays the description of the material style.
Details
Displays the Last saved by and Last saved dates.
Display tab
Defines general shape style settings.
View direction
Specifies for which view direction the display characteristics are modified. Two options are available:
  • Model
  • Section
Component display
Lists shape style components with assigned visibility and layer.
Component Type
Displays the component types.
Visible
Displays the component visibility. Click the light icon to change the visibility.
Color
Displays a color for the component. To change the color, click the field and select a new color in the Color dialog box.
Layer
Displays the layer for components. Choose another one from the drop-down list of available layers.
Linetype
Displays the linetype for the component. Choose another one from the drop-down list or the Load... option to open the Load Linetypes dialog box.
LT scale
Displays the linetype scale for the component. Click the field to edit.
Lineweight
Displays the lineweight for the component. Choose another one from the drop-down list.
Plot Style
Displays the plot style used for the component.
Component hatch display
Lists the hatch component characteristics.
Component
Displays the component name.
Pattern
Displays the hatch pattern. Click the right-side dots to open the Hatch Pattern Palette dialog box to choose another hatch pattern.
Angle
Sets or displays the hatch angle.
Scale
Sets or displays the hatch scale.
