Report panel
To open the Report panel, run the REPORTPANELOPEN command or right-click a ribbon panel/toolbar and choose Report from the Panels list.
The Report panel offers feedback for relevant commands including DMAUDIT, DMSIMPLIFY, DMSIMPLIFYALL, DMSTITCH, and all sheet metal (SM*) commands.
The appearance of the Report panel is determined by the REPORTPANELMODE system variable.
  1. Display grouping
  2. Report output
  3. Detailed items output
Display grouping
Specifies how information is grouped for the report.
  • Sort by Structure/Message/Subentity
  • Group by Message/Structure/Subentity
  • Group by Structure/Subentity/Message
Report output
Displays command output.
Shows detailed command output for selected item in the report output.
