BDEPENDENCYHIGHLIGHT system variable
Highlight dependent objects
Highlights all objects that are dependent on a selected action or parameter in the Block Editor.
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Dependent objects are not highlighted when an action or parameter is selected. On (1): Dependent objects are highlighted when an action or parameter is selected. |
