BACTION command
Adds an action to a parameter in a dynamic block definition.
Disclaimer
Important: In the event that you purchase BricsCAD in the U.S. or for use in the U.S., the feature to create or edit dynamic block definitions is neither available nor licensed to you. Please see EULA for more information.
Method
Note: This command is not available in Block Editor when editing a parametric block.
You can add an action to a parameter in a dynamic block definition to define how the block geometry moves or changes when the action is triggered in a dynamic block reference.
The action types available depend on the selected parameter:
  • Point parameter: move, stretch.
  • Polar: array, move, scale, stretch, polar stretch.
  • Linear parameter: array, move, scale, stretch.
  • XY parameter: array, move, scale, stretch.
  • Rotation parameter: rotate.
  • Flip parameter: flip.
  • Lookup parameter: lookup.
Select the parameter, the action type, the selection set (the geometry affected by the action), and the action location.
Options within the command
Array
Adds an array action to a linear, polar, or XY parameter.
Move
Adds a move action to a point, linear, polar, or XY parameter.
Scale
Adds a scale action to a linear, polar, or XY parameter.
Stretch
Adds a stretch action to a point, linear, polar, or XY parameter.
Polar stretch
Adds a polar stretch action to a polar parameter.
Multiplier
Changes the value of the associated parameter by the specified distance when the BACTIONBARMODE system variable is set to 0 and the action is triggered.
Offset
Increases or decreases the angle of the selected parameter by the specified value when the BACTIONBARMODE system variable is set to 0 and the action is triggered.
Xy
When an XY parameter is selected, specifies whether the distance applied to the action from the parameter's base point is the parameter's X distance, Y distance, or XY distance.
Base
Specifies whether the action's base point is dependent or independent of the base point of the associated parameter.
CPolygon
Defines the boundary area of an action (the entities modified by the action) by the specified polygon.
Undo
Undoes the last polyline segment and continue drawing from the previous point.
