BLOCKEDITLOCK system variable
Block editor lock
Disables the Block Editor (BEdit mode). Blocks cannot be edited.
Type:
Boolean
Saved in:
Registry
Default value:
Off
Related commands
  • BEDIT command
  • BESETTINGS command
Related variables
  • BEDITMODE system variable
  • BLOCKEDITOR system variable
Octave
