CLEANSCREENOPTIONS system variable
Clean screen options
Controls which UI elements are hidden by the CLEANSCREENON command.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 127 |
| Default value: |
15 |
| Possible values: |
1: Hide document tabs 2: Hide dockable panels 4: Hide toolbars 8: Hide Ribbon 16: Hide Command line 32: Hide Status bar 64: Hide menu bar |
