CREATESKETCHFEATURE system variable
Sketch based feature (experimental)
Links 3D entities created with the EXTRUDE, LOFT, SWEEP, and REVOLVE commands and their options Subtract and Unite to the 2D entities used to create them and converts the 2D entities into a sketch. Any modifications to the sketch are reflected in the 3D entity.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Range: |
0 to 1 |
| Default value: |
0 |
| Possible values: |
0: Do not create sketch based feature 1: Create sketch based feature |
Note: This system variable can also be set by pressing the Sketch Feature toggle button (
) in the ribbon.
) in the ribbon.
