DIMLAYER system variable
Default layer for new dimensions
The default layer for new dimensions.
Type:
String
Saved in:
Drawing
Default value:
Related commands
  • DIM command
  • DIM1 Command
  • DIMALIGNED command
  • DIMANGULAR command
  • DIMCONTINUE command
  • DIMLEADER command
  • DIMORDINATE command
