DRAWINGVIEWBGENPAR system variable
Parallel generation of drawing views
Enables parallel generation of drawing views during the VIEWBASE command.
Only effective when background generation is enabled.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
Off
Possible values:
Off (0): Disable parallel generation of drawing views
On (1): Enable parallel generation of drawing views
