DRAWINGVIEWBGENPAR system variable
Parallel generation of drawing views
Enables parallel generation of drawing views during the VIEWBASE command.
Only effective when background generation is enabled.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
Off |
| Possible values: |
Off (0): Disable parallel generation of drawing views On (1): Enable parallel generation of drawing views |
