DYNMODE system variable
Dynamic input mode
Toggles dynamic input features on/off.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
-31 to 31 |
| Default value: |
3 |
| Possible values: |
0: No dynamic input 1: Dynamic input at pointer (not yet supported) 2: Editable dynamic dimensions 4: Tracking dynamic dimensions 8: Nearest entity by UCS X/Y axes dynamic dimensions 16: Nearest entity dynamic dimensions |
Note:
- When DYNMODE is set to a negative value, all dynamic input features are turned off, but the corresponding value is stored.
- Click Dynamic Input (DYN) on the status bar to toggle the value of the DYNMODE system variable between positive and negative.
