IFCEXPORTTESSELATION system variable
Level of tessellation
Controls the exported geometry tessellation level during IFC export. When the Current faceting option is chosen, no regeneration is required, the faceting as set by FACETRES system variables or the Modeler Properties.
The Low, Medium, or High options cause regeneration of facets, which takes longer.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 3 |
| Default value: | 0 |
| Possible values: |
0: Current 1: Low 2: Medium 3: High |
