FACETRES system variable
Facet resolution
Controls the smoothness of shaded, rendered and hidden line views.
Values between 0.01 and 10.0 are accepted. Large values can have a significant impact on memory usage and performance.
| Type: |
Real |
| Saved in: |
Drawing |
| Range: |
0.01 to 10.0 |
| Default value: |
0.5 |
Note:
- Increasing the FACETRES value reduces the number of facets and enhances drawing performance.
- When a heavy drawing is stored with an inconveniently low FACETRES value, it can be difficult to open. Turning off the SPAUSEFACETRES system variable overrides FACETRES and applies the settings from MODELERPROPERTIES. See the SPAUSEFACETRES system variable and MODELERPROPERTIES command articles for more information.
