IFCSETTINGSCONFIG system variable
IFC settings configuration
Specifies the name of the IFC settings configuration file.
BricsCAD only
| Type: |
String |
| Saved in: |
Registry |
| Default value: | "bim_ifc_settings.xml" |
BricsCAD only
| Type: |
String |
| Saved in: |
Registry |
