INTERSECTEDENTITIES system variable
Resolve intersection
Controls how new entities, modify existing entities when they intersect. Applies to entities as they are created with the EXTRUDE and REVOLVE commands, when the Auto option is selected.
The INTERSECTEDENTITIES system variable is one of the four system variables found under the Extrude mode group.
BricsCAD only
Type:
Short
Saved in:
Workspace
Range:
0 to 2
Default value:
0
Note: The default value is 1 for the BIM and Mechanical workspaces.
Possible options:
0: Do not modify
1: Subtract from intersection
2: Unite at intersection
