LAYOUTREGENCTL system variable
Layout regeneration control
Controls how the display of the Model and layout tabs is updated. If performance is poor in general or when switching between tabs, setting LAYOUTREGENCTL to 1 or 0 might improve performance.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 2 |
| Default value: |
2 |
| Possible options: |
0: Always regenerate between when a tab is activated 1: Suppress the regeneration of the Model tab and last layout made current, and regenerate all other tabs when activated 2: Regenerate only the first time the tab is active |
