LEVELOFDETAIL system variable
Composition Level of detail
Controls the composition level of detail (LOD).
BricsCAD only
Type:
Short
Saved in:
Drawing
Default value: 0
Possible values:
0: Low
2: High
  • If 0: Composition plies do not display.
  • If 2: Composition plies display.
Related commands
  • BIMATTACHCOMPOSITION command
  • IFCEXPORT command
Related variables
  • IFCSETTINGSCONFIG system variable
  • RENDERCOMPOSITIONMATERIAL system variable
