OSMODE system variable
Entity snap mode
Controls the 2D entity snap types.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 32767 |
| Default value: |
4135 |
| Possible options: |
0: None 1: Endpoint 2: Midpoint 4: Center 8: Node 16: Quadrant 32: Intersection 64: Insertion 128: Perpendicular 256: Tangent 512: Nearest 1024: Geometric center 2048: Apparent intersection 4096: Extension 8192: Parallel 16384: Turn off all snaps |
