PSVPSCALE system variable
Paper space viewport scale
Controls the scale multiplier for new viewports created with the VPORTS command.
Note: The view scale multiplier is defined by comparing the ratio of units in paper space to the units in newly created model space viewports.
The view scale multiplier you set is used with the VPORTS command. A value of 0 means the scale multiplier is Scaled to Fit.
| Type: | Real |
| Saved in: | Drawing |
| Default value: |
0.0 |
