SHOWLAYERUSAGE system variable
Layer Usage
Shows information about layer usage in the Layers panel.
In the column Current, the Layer Usage icons indicate when viewport settings for the current layout and paper space viewport are different from model space settings:
: Current layer with viewport overrides.
: Layer with viewport overrides.
: Empty layer with viewport overrides.
Type:
Boolean
Saved in:
Registry
Default value:
Off
Possible values:
Off (0): Do not display Layer Usage
On (1): Display Layer Usage
