SPANORMALTOL system variable
Normal tolerance
Controls the maximum deviation allowed between two normals on two adjacent facet nodes, in degrees.
This value is independent of the model size. This variable is ignored if the FACETRES system variable is on (1).
Note: Spa is short for Spatial, the maker of ACIS.
BricsCAD only
Type:
Real
Saved in:
Preference
Default value:
15.0
