SPAUSEFACETRES system variable
Use FACETRES system variable
Use the FACETRES system variable in place of normal tolerances.
Note: Spa is short for Spatial, the maker of ACIS.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
On |
| Possible values: |
Off (0) On (1) |
Note:
- If On, the configuration relies on the FACETRES system variable. Other ACIS modeler settings are ignored.
- If Off, the configuration allows other ACIS modeler settings to override the FACETRES system variable.
