USESTANDARDOPENFILEDIALOG system variable
Use standard open file dialog (Windows)
Uses a standard (non-customizable) dialog for the OPEN, SAVEAS and INSERT commands (Windows only). See also the DRAWINGPATH, BLOCKSPATH and PLACESBARFOLDER system variables.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: | Off |
