SECTIONVIEWEDIT command
Edits section views of civil entities.
Icon:
Method
Select a section view or press the Enter key.
  • If you select a section view, you can choose in the Command line to edit a single or multiple section views.
  • If you press Enter, the Select Section Line Group dialog box opens, to select a section line group.
Then, the Edit Section Views dialog box opens for multiple section views, while the Edit Section View dialog box opens for a single section view.
The Edit Section Views dialog box allows you to edit section views.
Note: When is selected only one section view, the name of the dialog box is Edit Section View.
Section view information
Allows you to set the layer and style for the section views.
Layer
Sets the layer for section view by selecting it from the drop-down list.
Style
Sets the style for section views by selecting it from the drop-down list.
Press the three-dot button on the right to open the Select Style dialog box, where you can edit or copy a section view style.
Section line group
Displays the section line group name.
Frame settings
Opens the Frame Settings dialog box to set the width and the height of the frames. See the Frame Settings dialog box article for more information.
Section view(s)
Lists the selected section view or all section views created along the section line group.
Select all
Selects all section views.
Note: This button appears only when multiple section views are available.
Data sources
Lists the selected data sources for the current section line group.
You can deselect data sources that you want to be removed from the section views.
Also, for some data sources you can change the style.
Manage data sources button
Opens the Manage Data Sources dialog box.
Clip gridlines to
When ticked, it allows you to set the clip gridlines from the drop-down list.
Options within the command line
Multiple section views
Opens the Edit Section Views dialog box to select multiple section views in the Section views list.
Single section view
Accepts the selected section view and opens the Edit Section View dialog box.
press enter key to select section line group from the list
Opens the Select Section Line Group dialog box.
