ARRAYEDIT command
Edits associative arrays.
Icon:
Method
Select the entities that make up associative arrays.
Options
- Source
Edits the source entities of the array.
Note: Displays Array Editing State dialog box. Only the selected entity is displayed in Associative Array Edit environment so it can be easy to modify, add and delete entities. The changes are applied to all the entities once the array editing state is closed.
- REPlace
- Replace some or all the entities in the array.
- RESet
Restores erased entities and removes any item overrides.
Note: Holt the Ctrl key to select more than one item in the associative array, then tap the Delete key to erase the selection.
- eXit
- Accept the changes and conclude the command.
