Creates a continuous line or arc from an existing linear, angular, or ordinate dimension. The dimensions are based on the current dimension style.
Methods to create continuous dimensions
This command has 2 methods to begin creating continuous dimensions:
Origin of next extension line
Select starting dimension
Begin creating continuous dimensions from the last linear, angular, or ordinate dimension by specifying a point for the next extension line.
For linear and angular dimensions, the first extension line of each continuous dimension coincides with the second extension line of the previous dimension.
Continue placing dimensions until you press Enter to end the command.
