FLIPLINE command
Creates a line, used to flip the entities of a block.
Methods
This command is used with 2D parametric blocks.
The FLIPLINE command allows you to draw a line used as a reference axis for flipping the selected entities of the block. When the flip line is created, it has a green color and it is moved to a special layer named FLIPLINES.
The FLIPLINE command will automatically create a special type of parameter and will associate it to the flip line entity. This parameter has two possible values: Not Flipped and Flipped.
The flip of the block will occur when the value of the flip parameter is changed. You can access this parameter in the Parameters Manager panel. Another way to change the flip parameter is to select the block and open the Properties panel, in the Parameters section.
When the flip parameter is set to Not Flipped, the block is in its default configuration, as it was drawn. When the flip parameter value is changed to Flipped, the block is flipped around the flip line.
Options within the command
- Specify what to flip
- Specifies the mode to select entities to be flipped.
- Angle
- Specifies the angle of the line segment.
- Length
- Specifies the length of the line segment.
- Undo
- Undoes the last line segment and continues drawing from its previous start point.
- Close
- Automatically draws a line from the end point of the last segment to the start point of the first segment.
